Maly501 Posted October 29, 2017 Share Posted October 29, 2017 (edited) Mam problem z wentylatorem chłodnicy otóż nie włącza się mimo że Klima jest włączona miałem go podpiete pod kompa i komp to zalancza a on nie rusza Edited October 29, 2017 by Maly501 Quote Link to comment Share on other sites More sharing options...
m@rcin sz-n Posted October 29, 2017 Share Posted October 29, 2017 Klima sprawna ,nabita? Quote Link to comment Share on other sites More sharing options...
Maly501 Posted October 29, 2017 Author Share Posted October 29, 2017 (edited) Tak. Komp to wlancza na pirwsz bieg potem drugi a on nic Edited October 29, 2017 by Maly501 Quote Link to comment Share on other sites More sharing options...
DINO Posted October 29, 2017 Share Posted October 29, 2017 a zasilanie jest wtedy na wtyczce?? podłączyłeś na krótko czy działa?? Quote Link to comment Share on other sites More sharing options...
Maly501 Posted October 29, 2017 Author Share Posted October 29, 2017 (edited) A nakrotko nieprubowalem.może być zjadamy Edited October 29, 2017 by Maly501 Quote Link to comment Share on other sites More sharing options...
DINO Posted October 29, 2017 Share Posted October 29, 2017 od tego bym zacząl Quote Link to comment Share on other sites More sharing options...
Maly501 Posted October 29, 2017 Author Share Posted October 29, 2017 Dac mu bez pośrednio + i - Quote Link to comment Share on other sites More sharing options...
DINO Posted October 29, 2017 Share Posted October 29, 2017 inaczej nie sprawdzisz Quote Link to comment Share on other sites More sharing options...
scanik Posted October 29, 2017 Share Posted October 29, 2017 Mozesz tez jechać na kompa, niech z pozycji laptopa włączy Wysłane z mojego SM-G930F przy użyciu Tapatalka Quote Link to comment Share on other sites More sharing options...
Maly501 Posted October 29, 2017 Author Share Posted October 29, 2017 (edited) Wiatrak na krótko dziala bezpiecznik ten niebieski 50-30-40 wygląda na caly Edited October 29, 2017 by Maly501 Quote Link to comment Share on other sites More sharing options...
DINO Posted October 29, 2017 Share Posted October 29, 2017 wygląda czy jest cały?? zasilanie na wtyczce jest?? Quote Link to comment Share on other sites More sharing options...
Maly501 Posted October 29, 2017 Author Share Posted October 29, 2017 Niestety niemam miernika,no wygląda nacaly nie widać żeby był spalony Quote Link to comment Share on other sites More sharing options...
DINO Posted October 29, 2017 Share Posted October 29, 2017 do tego miernik nei jest potrzebny, nieraz pomaga wyjęcie i włożenie bezpiecznika, sprawdź jeszcze, czy jakiś kabel się nie przetarł od wtyczki Quote Link to comment Share on other sites More sharing options...
Maly501 Posted October 29, 2017 Author Share Posted October 29, 2017 Ok spróbuje ale to to jest ten bezpieczni? Czy jest jeszcze jakoś? Quote Link to comment Share on other sites More sharing options...
DINO Posted October 29, 2017 Share Posted October 29, 2017 powinny być opisane Quote Link to comment Share on other sites More sharing options...
Lasiat Posted November 1, 2017 Share Posted November 1, 2017 Jeszcze można sprawdzić przekaźnik. Quote Link to comment Share on other sites More sharing options...
Maly501 Posted November 4, 2017 Author Share Posted November 4, 2017 Jutro jestem zkumplem elektrkiem umówiony. Zobaczmy Powdem był rezystor. Dzięki za podpowiedzi. Temat zamkniety Quote Link to comment Share on other sites More sharing options...
Recommended Posts
Join the conversation
