akumulator + radio kod
MIROGN
Witam, muszę wymienić akumulator w T32 1,6 dci czy po odłączeniu aku radio będzie wołało kod?
pytam ponieważ nie mam kodu do radia
Edytowane przez MIROGN
On 12/3/2022 at 9:53 AM, MIROGN said:
Hello, I need to replace the battery in the T32 1.6 dci, will the radio call the code after disconnecting the battery?
I'm asking because I don't have the code for the radio
Hello. I changed the battery last month, and no code was required.
I understood that the code is coded in the car key.
