[P12/WP12] Zablokowane radio po zmianie smart entrance!!!
Gość zaxa10
Witam!!!
Juz od dłuzszego czasu mecze sie z napisem securit na wyswietlaczu.Po wizycie w ASO kazano mi wymienic moduł smart entrance, bo to moze byc przyczyna.Kupiłem ten moduł, a radio dalej nie chula.Teraz kazano mi kupic goly kluczyk, dorobić go i przelozyc ze starego kluczyka pilot do nowego , bo byc moze jest uszkodzony transporder w kluczyku.Jezeli to nie pomoze to proponuja wysłac radio do Clariona w Warszaawie.Podejrzewam, ze radio nie jest z tego auta, a bez muzyki w aucie tak ponuro.
Czy ktos z Was ma jakies pomysly???
Witaj, tu masz opis problemu z instrukcji serwisowej. Tekst jest w miare prosty powinienes dac sobie rade. Mnie tez padl Smart Entrance, ale raczej zdecyduje sie na naprawe, lub jak sie nie da podlacze jakis sciemniacz z allegro ca. 40PLN z przesylka.
When the radio is locked
When NATS link problems occur “SECURE” message will be displayed in three ways indicating three different NATS link problems.
“Secure” on a red background indicates that there is a problem in the link between Navi control unit and Audio, suggesting that there is either a Navigation system fault or the Navi control unit has previously been fitted in another vehicle.
“Secure” on a green background indicates that there is a problem in the link between NATS IMMU and Audio, suggesting that there is an audio fault or the audio unit has previously been fitted in another vehicle.
“Secure” on a yellow background indicates that the transponder (NATS key) is not working correctly or it has previously been fitted in another vehicle.
When a “Secure” message (of any type) is displayed, it can be cleared by re-initializing the NATS system using CONSULT-II and the associated Immobilizer PIN code (there is no need to return the audio to a Clarion AUDIO service centre). If re-initializing fails to clear a “Secure” message then the component (identified by background color) is faulty and should be replaced.
pozdrawiam
ciechon
Aż mnie nosi jak czytam o "kompetencjach" ekspertów z ASO Nissan. Jesteś jedną z wielu ofiar tych oferm. Jak można wyczytać z manuala by ciechon Smart .. nie pojawia się ani razu jako potencjalna przyczyna Twojego problemu ale za to jasno opisuje co jest w zależności od kolory tła, na Twoim miejscu wydrukował bym ten kawałek serwisówki i zażądał zwrotu kasy za moduł, te ćmoki powinny znać serwisówke jak biblie i w 3 s powiedzieć Ci co jest z Audio, to jest podstawowy obowiązek ASO a nie k..a jakieś "może być uszkodzony" "to może być przyczyna" To jest q..a samochód a nie kasyno i tu logika rozmyta nie obowiązuje albo coś jest dobre albo zepsute. Uff przepraszam za słownictwo, napisz co z tego wyszło.
Mnie tez juz krew zalewa!!!
U mnie napis securit swieci sie na zółto, wiec jest jakis problem z kluczykiem.Mam tylko jeden i wynika z tego ze transponder nie byl od tego auta a jedynie przeprogramowany i dlatego nie działa radio-tak mi sie wydaje.Nie wiem teraz czy kupowac nowy kluczyk, czy cos innego wykombinowac.Co polecacie?
W manualu masz odpowiedź, trzeba podłączyć CONSULT-II i zrestartować (ponownie zainicjować) system NATS używając PIN do NATS (4 cyfrowy) który albo masz w dokumentacji (zwykle mała naklejka w gwarancji-książce serwisowej) albo serwis Nissana jest w stanie pozyskać go z centrali na podstawie numeru VIN. Drugi kod (od kluczyka) jest 5 cyfrowy i przy nowym jest wydawany na takim tagu plastikowym.
Powodzenia
PS
Nowy kluczyk raczej nie rozwiąże problemu.
Gość w Aso powiedział, ze w nowym kluczyku bedzie transponder czysty, który oni zaprogramują tak, ze bedzie współgrał z immo.Niestety nie mam ksiązki serwisowej, ani zadnych kodów i tylko jeden kluczyk.A w tym manualu, jest napisane ,ze jesli sie pali secure na żółtym tle to jest problem z kluczykiem i ma to sens.
O kody się nie martw w ASO można odszukać kod po numerze VIN, wiem, że kontaktują się z nissanem w GB, ja nie miałem kodu i go zakupiłem łącznie z nowym kluczykiem i ze starym kodem.
Panowie mialem to samo. Po dlugim poszukiwaniu i pomocy jendego kolego trafilem na Wolumen. Tam mi nie pomogli, ale dali namiar na Pana tez w W-wie ktoremu zajelo to 15 minut - wyczyscil radio i stalo sie ono jak nowe dla auta. Poznikaly napisy Secure i Please wait i wszystko super dziala. Jutro poszukam wizytowki i podam namiar zainteresowanym na PW
[ Dodano: Pon 28 Lip, 2008 21:51 ]
Aha, dodam ze u mnie Secure bylo zielone jak nie bylo radia, a jak podlaczalem radio to pojawialo sie Please wait na zoltym tle. Facet wyczyscil radio
poszlo na pw
[ Dodano: Wto 29 Lip, 2008 06:30 ]
Wiesz, ja mialem lepszy przypadek. Bo jak im pokazalem serwisowke, to powiedzieli ze serwisoka sie myli i sie nie da :) Mam kupic nowe radio i juz.
Witaj radkow,
mam poważny problem z radiem na wyswietlaczu pisze secure i nic sie nie da zrobic , czytałem ze miałes podobny problem ale znalazles faceta który to potrafi zrobic , czy mógł bys podac mi numer telefonu do niego? U mnie secure wyświetla sie w czerwonej ramce na środku wyswietlacza
bede bardzo wdzieczny POZDRAWIAM
sytuacja została opanowana
w moim przypadku wystarczyło kupić cały zestaw 2 urządzenia cd + dvdrom i zamienic nie mozna wymieniać tylko samego dvd romu albo cd, bo nic to nie da, tylko kompletem z innego samochodu ( mówimy tutaj o uzywanym sprzęcie )
(SECURE NA CZERWONYM TLE)
mam nadzieję ze takie info Wam sie przyda w przyszłości
a co do serwisów nissana to szkoda , że taka instytucja istnieje :):) 0 wiedzy na temat takiej błachej sprawy a jeśli nawet coś ktos wie ( ale nie wiedzieli:) ) to ceny sadzą jakieś kosmiczne :) śmiech na sali panowie
