B 52 Opublikowano 11 Stycznia 2010 Udostępnij Opublikowano 11 Stycznia 2010 MARKA MODEL ROK PRODUKCJI ILOŚC BIEGÓW FWD/RWD TYP SKRZYNI NISSAN 200SX(1,6L) 1995-1998 4 FWD RL4F03A NISSAN 200sx(1,8l) 1984-1988 4 RWD L4N71B NISSAN 200SX(2,0L) 1980-1983 3 RWD L3N71B NISSAN 200SX(2,0L) 1995-1998 4 FWD RE4F03A NISSAN 200SX(2,2L) 1980-1983 3 RWD L3N71B NISSAN 200SX(3,0L) 1987-1988 4 RWD E4N71B NISSAN 240SX 1989-1998 4 RWD RE4R01A NISSAN 280ZX 1980-1983 3 RWD L3N71B NISSAN 300ZX 1984-1989 4 RWD E4N71B NISSAN 300ZX 1989-1997 4 RWD RE4R01A NISSAN 300ZX 1990-1997 4 RWD RE4R03A NISSAN 350Z 2003-2005 5 RWD RE5R05A NISSAN ALTIMA 1993-1999 4 FWD RE4F04A NISSAN ALTIMA 2000-2004 4 FWD RE4F04B NISSAN ALTIMA 2005 4 FWD RE4F04B NISSAN ALTIMA 2005 5 FWD RE5F22A NISSAN ARMADA 2004-2006 5 RWD RE5R05A NISSAN AXXESS 1990 4 FWD RL4F02A NISSAN FRONTIER(2,4L) 1998-2004 4 RWD RL4R01A NISSAN FRONTIER(2,5) 2005 5 RWD/4WD RE5R05A NISSAN FRONTIER(3,3L) 1999-2004 4 RWD RE4R01A NISSAN MAXIMA 1980-1982 3 RWD L3N71B NISSAN MAXIMA 1983-1984 4 RWD L4N71B NISSAN MAXIMA 1985-1988 4 FWD RL4F02A NISSAN MAXIMA(3,0L) 1992-1999 4 FWD RE4F04A NISSAN MAXIMA(3,0L) 1989-1994 4 FWD RE4F02A NISSAN MAXIMA(3,0L) 2000-2003 4 FWD RE4F04B NISSAN MAXIMA(3,5L) 2005-2006 5 FWD RE5F22A NISSAN MAXIMA SE 2004 5 FWD RE5F22A NISSAN MAXIMA SL(3,5L) 2004 4 FWD RE4F04A NISSAN MURANO 2003-2005 CVT CVT RE0F09A NISSAN NX 1992-1993 4 FWD RL4F03A NISSAN PATHFINDER (2,4L) 1986-1989 4 RWD L4N71B NISSAN PATHFINDER(2,4L) 1990-1997 4 RWD RL4R01A NISSAN PATHFINDER(3,0L) 1986-1987 3 RWD L3N71B NISSAN PATHFINDER(3,0L) 1986-1989 4 RWD L4N71B NISSAN PATHFINDER(3,0L) 1988-1989 4 RWD/4WD RE4R01A NISSAN PATHFINDER(3,0-3,5L) 1990-2004 4 RWD RE4R01A NISSAN PATHFINDER(4,0L) 2005 5 RWD/4WD RE5R05A NISSAN PICKUP 1980-1985 3 RWD L3N71B NISSAN PICKUP 1986-1987 3 RWD L3N71B NISSAN PICKUP 1986-1989 4 RWD L4N71B NISSAN PICKUP(2,4L) 1990-1997 4 RWD RL4R01A NISSAN PICKUP(3,0 3,3L) 1990-1997 4 RWD RE4R01 NISSAN PICKUP(3,0 3,3L)AWD 1990-1997 4 RWD RE4R01A NISSAN PICKUP 4WD 1988-1989 4 RWD RE4R01A NISSAN PULSAR(1,5 1,6L) 1983-1990 3 FWD RL3F01A NISSAN PULSAR(1,8L) 1988-1990 4 FWD RL4F02A NISSAN QUEST S/SL/SE 1993-2005 4 FWD RE4F04A NISSAN QUEST 2004-2005 5 FWD RE5F22A NISSAN SENTRA 1982-1992 3 FWD RL3F01A NISSAN SENTRA(1,6L) 1982-1992 3 FWD RL3F01A NISSAN SENTRA(1,6L) 1991-1999 4 FWD RL4F03A NISSAN SENTRA(1,8L) 2000-2005 4 FWD RE4F03B NISSAN SENTRA(2,0L) 1982-1992 3 FWD RL3F01A NISSAN SENTRA 1991-1992 4 FWD RL4F03A NISSAN SENTRA 1993-1999 4 FWD RE4F03A NISSAN SENTRA 2000-2005 4 FWD RE4F03B NISSAN SENTRA 2000-2005 4 FWD RE4F04B NISSAN STANZA 1982-1985 3 FWD RL3F01A NISSAN STANZA 1986-1989 4 FWD RL4F02A NISSAN STANZA 1990-1992 4 FWD RE4F02A NISSAN TITAN 2004-2006 5 RWD RE5R05A NISSAN VAN 1987-1989 4 RWD L4N71B NISSAN VAN 1989 4 RWD RE4R01A NISSAN VARIOUS 1969-1982 3 RWD BW-T35 NISSAN VARIOUS 1972-1982 3 RWD L3N71B NISSAN XTERRA 2000-2004 4 RWD/4WD RE4R01A NISSAN XTERRA 2005 5 RWD/4WD RE5R045A Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Gość wpierdol20 Opublikowano 20 Stycznia 2010 Udostępnij Opublikowano 20 Stycznia 2010 możesz kody skrzyni manualnej wkleić? Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
B 52 Opublikowano 23 Stycznia 2010 Autor Udostępnij Opublikowano 23 Stycznia 2010 Tylko automaty Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Gość Świerzak Opublikowano 10 Lipca 2010 Udostępnij Opublikowano 10 Lipca 2010 (edytowane) Skasować Edytowane 10 Lipca 2010 przez Świerzak Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
B 52 Opublikowano 26 Października 2010 Autor Udostępnij Opublikowano 26 Października 2010 Skasować Nie skasować tylko zmienić skrzynie na wygodniejszą. Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Gość R35 Opublikowano 8 Stycznia 2012 Udostępnij Opublikowano 8 Stycznia 2012 Wszytko fajnie tylko to NISMO.... Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Navstar Opublikowano 15 Czerwca 2012 Udostępnij Opublikowano 15 Czerwca 2012 To sa tylko do automatow? Jak moge sprawdzic typ skrzyni w p11 2.0 TD 1996r ? Podobno sa dwa typt skrzyni w tych p11. Prosze o szybka pomoc, jutro musze zalac skrzynie nowym oleje, a nie wiem co wybrac a nie chce zaszkodzic :/ Wiem juz ze, niecale 4 l sie mieszcza Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Qadrat Opublikowano 15 Czerwca 2012 Udostępnij Opublikowano 15 Czerwca 2012 Jeśli by ktoś do N15 szukał, to: Nissan Almera N15 silnik 1.4 skrzynia RS5F30A. Oleju wchodzi od 2.8 do 3 litrów. Najlepszy będzie syntetyk 75W90 GL-4 (nie lać GL-5!). Wymiana niewskazana, jedynie okresowe sprawdzanie stanu oleju. Nissan Almera N15 silnik 1.6 oraz 2.0D skrzynia RS5F31A. Oleju wchodzi od 2.9 do 3.2 litrów. Najlepszy będzie syntetyk 75W90 GL-4 (nie lać GL-5!). Wymiana niewskazana, jedynie okresowe sprawdzanie stanu oleju. Nissan Almera N15 skrzynia automatyczna RL4F03A 34x68. Oleju wchodzi 7 litrów, typ oleju to ATF, wymiana co 60tys. km. P.S. Jak N15 wyjeżdżały z fabryki, to skrzynie ponoć miały zalewane olejem 75W80. P.S.2 W Primerze P11 2.0TD z 1996r jest skrzynia RS5F32A. Wchodzi tam 3.6 - 3.8 litrów oleju. Najlepiej zalej tak, jak w przypadku N15 - olej 75W90 GL-4, mogę polecić CASTROL TAF-X 75W90. Pół litra kosztuje 30zł, ale jak zalejesz czymś tandetnym, to zimą nie znajdziesz biegów. Jeśli teraz Ci biegi dobrze wchodzą, poziom oleju jest odpowiedni - przemyśl dobrze, czy aby na pewno chcesz zmieniać ten olej 1 Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Navstar Opublikowano 18 Czerwca 2012 Udostępnij Opublikowano 18 Czerwca 2012 Dzieki kolego Znalazlem juz w instrukcji info Ale nr skrzyni sie przyda na przyszlosc Musze wymienic olej, bo wymieniam pol os i trzeba by dolac z pol litra, ale nie mam pojecia co tam bylo wlane Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Gość jacob374 Opublikowano 12 Marca 2014 Udostępnij Opublikowano 12 Marca 2014 Tylko automaty Nissan Almera N15 skrzynia automatyczna RL4F03A 34x68. Oleju wchodzi 7 litrów, typ oleju to ATF, wymiana co 60tys. km. Tylko automaty Nissan Almera N15 skrzynia automatyczna RL4F03A 34x68. Oleju wchodzi 7 litrów, typ oleju to ATF, wymiana co 60tys. km. ............................??? ----------------------------------------------------------- ileatherwear ileatherwear.com womens leather jacket womens leather jacket pmp training pmp training Tylko automaty Nissan Almera N15 skrzynia automatyczna RL4F03A 34x68. Oleju wchodzi 7 litrów, typ oleju to ATF, wymiana co 60tys. km. ............................??? ----------------------------------------------------------- ileatherwear ileatherwear.com womens leather jacket womens leather jacket pass-4sure.net www.pass-4sure.net Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
azorek Opublikowano 14 Stycznia 2016 Udostępnij Opublikowano 14 Stycznia 2016 Ktoś wie w czym prócz Nissana Y720 mogła jeździć skrzynia z oznaczeniem ZL 71B #2 Albo kto w Polsce może mi ją naprawić? Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
