Turbina-jakie oznaczenie czesci ?
PeterUK
czy chodzi o to?
\ Nissan parts catalog \ PRIMERA \ P12E \ Browse parts \ Engine mechanical \ Turbo charger \ Illustration #2
Turbo charger — Illustration #2, Nissan PRIMERA 2003
Model PRIMERA Body Code P12E Production date '03, February Region Europe (left-hand drive) Body SEDAN Engine YD22DDT TYPE ENGINE Eng pwr 100KW Grade ELEGANCE TYPE Transmission 6-SPEED MANUAL TRANS
Pos
Description
Part number
Supplement
Date
Quantity
Weight
1 Turbocharger outlet gasket 1 0.017 kg / 0.038 lb 14445AD200 '01, December — '04, June 2 Nut 3 0.011 kg / 0.024 lb 0121100151 '01, December — '04, June 3 Stud 6 0.025 kg / 0.055 lb 14416VB300 '01, December — '03, September 4 Turbocharger inlet gasket 1 14415AU600 '01, December — '04, June 5 Nut-outlet 3 0.015 kg / 0.033 lb 140944P101 '01, December — '04, June 6 Turbocharger 1 14411AU600 '01, December — '04, June 14411AW400 alternate: 14411AW40A '03, January — '04, June 7 Insulator-heat, turbine housing 1 0.198 kg / 0.437 lb 144504N100 alternate: 144504N10A '01, December — '04, June 8 Bolt 0.005 kg / 0.011 lb 081A86121A
HTML Code for this illustration image <a href="http://nissan4u.com/parts/primera/el_p12e/2003_2/type_67/engine_mechanical/turbo_charger/illustration_2/"'>http://nissan4u.com/parts/primera/el_p12e/2003_2/type_67/engine_mechanical/turbo_charger/illustration_2/" target="_blank"><img src="http://static.nissan4u.com/epc_img/1441631615924.png" border="0" /></a>
<< Previous illustration
Next illustration >>
nawet się zgadza
http://allegro.pl/nissan-primera-p12-2-2-dci-turbosprezarka-i2921979825.html
